Could anyone help me with cam specs. on cam part number could be TP147 (this might be a seal power or TRW number). Looking to set valves.
Camshaft Help!!!
Re: Camshaft Help!!!
Mike----
The Sealed Power/Federal Mogul cam of their part number TP147 is a clone of the GM #3927140, the so-called "Z-28 Off-Road Cam". Duration @ 0.050" is 257 degrees I/270 degrees E. Valve lift is 0.493"I/0.512"E. Lobe separation angle is 112 degrees.
GM adjustment specs are 0.024" I and 0.026" E.
By the way, in my opinion this cam is too radical to use on a street engine.In Appreciation of John Hinckley- Top
I agree - that cam was designed for use in the Trans-Am cars, with Traco-built engines and cross-ram manifolds, with open headers, for WOT performance between 4000-8000 rpm. It's not street-friendly, and will develop even less low and mid-range torque than the "30-30" cam.- Top
In addition you would be lucky to get even 10 MPG with that cam in normal driving on a SB, if that's important to you. It will have terrible idle quality/stability and not make any torque/power until about 4000 RPM.
It also requires high rate springs that will place the valvetrain in jeopardy in normal low speed driving.
That cam is strictly for SERIOUS racing only!
Duke- Top
