Still trying to understand the wiring for the wiper override light in the center console. There is a single black wire (I presume this is a positive wire) to the console bulb and the light is grounded to the console itself.
The wiper override switch (beneath the steering column), as I understand it for an April 68 build, cuts the GROUND to the wiper motor. I am not understanding when/how the wiper override light in the center console is actuated by the wiper override switch. I checked the owner's manual and it doesn't help. The AIM doesn't give enough information to answer the question. Things seem to have change during the model year and changed completely for 69.
It should be noted that the wiper motor is a rebuilt original and the entire car has been re-wired with a Lectric Unlimited harness. The dash is buttoned up and we don't want to rip things apart to poke around. The passenger portion of the lower dash is open, which provides access to the bulb.
HELP !
Need to understand where the black wire to the wiper override bulb in the center console goes. Logically, it should be connected somehow to the wiper motor, so that when the override switch is used (cutting the ground to the wiper motor) it powers the wiper override light ont he center console. Other potential choices for the black wire is to the wiper control switch, the wiper relay etc. As mentioned, don't want to rip the dash apart again to figure it out.
Chuck Faillace
68, L-36, M-20, A/C
HELP !
Need to understand where the black wire to the wiper override bulb in the center console goes. Logically, it should be connected somehow to the wiper motor, so that when the override switch is used (cutting the ground to the wiper motor) it powers the wiper override light ont he center console. Other potential choices for the black wire is to the wiper control switch, the wiper relay etc. As mentioned, don't want to rip the dash apart again to figure it out.Thanks
Chuck Faillace
68, L-36, M-20, A/C
