C1 Overheating - NCRS Discussion Boards
C1 Overheating
  • Mark R.
    • October 22, 2006
    • 23
    C1 Overheating
    Hi - Is it common for stock c1's to run hot? In traffic my (restored) temp gauge goes 80% to the right. Should I consider an aftermarket auxillary fan? Mark (in SC)
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: C1 Overheating
    Mark,
    Before doing anything I would suggest that you beg, borrow or buy a heat measuring gun. Check the temp at the sending unit and compare it to your gauge. Try and do it in a few temperature steps.
    If you see a consistent difference you can possibly put a resistor in the line to lower the gauge reading.
    This is a common C1 occurence.
    Good luck.
    Bruce B.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17882
      Re: C1 Overheating
      Mark, do a search as there was post 3-4 wks back about C1 temp senders calibration that might help you. Regards, Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
