C2 Tie rod Clamp Orientation - NCRS Discussion Boards
  • Joseph T.
    • March 1, 1986
    • 169
    I am having one of those moments. Can someone post a picture of both clamps Orientation on the tie rod sleeves. Or even a detailed explanation of Which way the clamps and the bolt heads face on both ends? I can not seem to find it in the 67 assembly manual. Thank you in advance
    Re: C2 Tie rod Clamp Orientation
    See UPC 9, Sheet 2, Views "A" and "B".
    • Jim S.
      • August 31, 2001
      • 730
      I can't tell you if the 1975 Corvette tie rods and clamps are the same as the C2 but they might be. This paper explains all about clamps and adjusters with respect to the AIM sheets.
      Hope that it helps,
      Jim Shea
        • 43281
        Hope that it helps,
        Jim Shea
        Jim-----
        The C2 tie rods and tie rod sleeves were exactly the same as C3. The C2 tie rod sleeve clamps were slightly different in configuration than C3 but are functionally identical and 100% interchangeable.
