Help Needed to Identify Part - NCRS Discussion Boards
  • Robert K.
    • June 30, 2001
    • 212
    Would anyone be able to help me identify the part shown? I've attached three pictures (top, bottom and side). Note that on the bottom view there is a number (312775).
    Thanks for your help!
    • 43263
    Re: Help Needed to Identify Part
    Robert-----
    I don't recognize it, at all. However, assuming that the '312775' is a GM part number (which I kind of doubt), I believe it was a number assigned to some Chevrolet truck application.
    • Robert K.
      • June 30, 2001
      • 212
      Joe,
      Thanks for the quick response - I think you're correct (I don't believe it's a GM part number either. There appears to be a logo which is a circle and inside of the circle appears to be a square (slightly squewed to the right, with the letter "M" in it or a checkmark........ I've attempted to draw it on the attachment......
      Does any of that make sense?
      I am having difficulty attaching a larger picture - you probably can't enlarge the photo I attached, can you?
        • 43263
        Joe,
        Robert-----
        Those are symbols I've seen on other castings. I'm sure it's the identifier for the foundry.
        No, I wasn't able to enlarge your photos. It might be possible, but I don't know how to do it.
        • Robert K.
          • June 30, 2001
          • 212
          One more time with a larger picture......I don't know if that helps any....
          Thanks Joe,
