1953-1962 Gas Cap - NCRS Discussion Boards
1953-1962 Gas Cap
  • Anthony L.
    • August 31, 1989
    • 17
    1953-1962 Gas Cap
    Hello All,
    Are 1953-1962 gas caps all the same? I have seen a few advertised as NOS that state 1953-1962 are the same, the ones with the four ears. Is this correct? Any information would be appreciated.
    Anthony
    • 43221
    Re: 1953-1962 Gas Cap
    Originally posted by Anthony LaFerrara (15626)
    Hello All,
    Anthony
    Anthony-----
    FUNCTIONALLY, I think they were the same. However, there were at least SIX different caps used over the 53-62 period.
      • May 31, 1974
      • 8385
      not functionally all the same.some vented, some not vented which would interfer with functionality.mike
      • Anthony L.
        • August 31, 1989
        • 17
        Thanks Joe!
        • Anthony L.
          • August 31, 1989
          • 17
          Again, Thanks Mike.
          • Roy B.
            • February 1, 1975
            • 7044
            53 to 57 left is original round rivets/right is repro flat rivets
              • 43221
              mike-----
              I thought there was a difference over the years as far as vented versus non-vented, too. However, the 1962 cap, GM #3814436, which I believe is a vented cap, was also used to SERVICE all 1953-61. So, I figured I was wrong about vented versus non-vented.
              • Roy B.
                • February 1, 1975
                • 7044
                mike-----
                53-57 I pic'ed was a vented gas cap later the gas tanks were vented not really needing a vented cap.
                • Anthony L.
                  • August 31, 1989
                  • 17
                  Thanks for the information Roy
                  • Dennis A.
                    • April 30, 1999
                    • 1010
                    Some where I had it that three styles of non-vented have been used...Part Number 3751027 is believed to be the Fuller Emerson cap, the Standt and Eaton caps may have been used in earlier cars???
                      '56 thru mid-'57 tanks weren't vented, and used vented caps. Mid-'57 thru '62 tanks were vented, and used non-vented caps. Photos below show the Fuller-Emerson non-vented cap, the new reproduction Stant non-vented cap, and the '56-'57E Eaton vented cap.
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        '56 thru mid-'57 tanks weren't vented, and used vented caps. Wonder why they kept using vented cap?Mid-'57 thru '62 tanks were vented, and used non-vented caps. Photos below show the Fuller-Emerson non-vented cap, the new reproduction Stant non-vented cap, and the '56-'57E Eaton vented cap.
                        Just asking
                          Originally posted by Roy Braatz (182)
                          Just asking
                          The non-vented cap was introduced concurrently in production with the mid-season change to the vented tank, and the TSB that instructed the dealers how to convert a non-vented tank to add the soldered-on vent nipple in the field also told them to discard the existing cap and replace it with the new non-vented cap.
                          • Roy B.
                            • February 1, 1975
                            • 7044
                            I'm learning every day Thanks for the info
                            In 54 there was a call back to correct water leaking into the cab area by drilling a hole at each door rubber gutter and adding a brass tube so as to drain the water under the body.Also adding a rubber patch at the door front area.
