71 BB Temp Switch - NCRS Discussion Boards
71 BB Temp Switch
  • Kenneth T.
    • March 23, 2008
    • 631
    71 BB Temp Switch
    My LS5 has a bayonet type temp sender in the driver's side cyl head. There is a plug in the pass side head. I have seen older BB's with a temp sender on the pass head.
    The reason I ask is that I have a wire coiled up by the heater box that has a black slip on female end that could be used on that type of temp sender. It that used for the CEC control or is it just....there ?
  • Warren F.
    • December 1, 1987
    • 1516
    Re: 71 BB Temp Switch
    Ken,
    The passenger side TCS (temperature control switch) is a double spade connection that the green wire is hooked to. Your car should have it as factory installed.
      • 43219
      Kenneth-----
      The temp sender on the forward driver side cylinder head is for the temperature gauge. It was originally a pin terminal. Most, if not all, replacements for the last 30 years, or so, have a button head. Any other terminal configuration indicates a functionally incorrect temp sender.
      A temperature SWITCH was mounted on the rear passenger side cylinder head. This switch used blade connectors mounted at a 90 degree angle. This switch was part of the TCS component of the CEC emissions control system. Many folks disabled this and that may be why yours is missing.
      • Kenneth T.
        • March 23, 2008
        • 631
        Warren, Joe:
        Thank you, correct as always! I actually routed through "my box" of old parts and found the old sender. I did a valve job on it years ago and must have removed it. It's a process, but I am getting closer...
        Ken
