1962 Pittman arm - NCRS Discussion Boards
1962 Pittman arm
  • Terry D.
    • May 31, 1987
    • 2696
    1962 Pittman arm
    Does anyone know what size the nut is the holds the pittman arm on? Also is the washer a flat washer or a lock washer?
    Re: 1962 Pittman arm
    I believe it's 1-5/16", and uses a split lock washer.
    • Terry D.
      • May 31, 1987
      • 2696
      Thanks John, I seem to have misplaced it somehow, I'm blaming it on the gremlins that live in my garage!
        • 43247
        John and Terry-----
        I think you're thinking of the 63-82 nut which was 1-5/16" across the flats. That nut was 7/8-14 thread size.
        The 53-62 nut was 3/4-16 thread size, 3/8" thick and 1-1/4" across-the-flats. It was originally GM #254291 and last available under GM #7809779 which is discontinued without supercession.
        Although not an "official" supercession, I believe that GM #9414953 could be used for a replacement. It's the same 3/4-16 thread size and it's of GM 301M material grade. However, it's almost twice as thick as the original nut.
        • Terry D.
          • May 31, 1987
          • 2696
          Joe
          Thanks for the info, I'll check with my local Chevy store, originality is not a concern, not remembering where I misplaced a nut that size is a different matter.
          • Mike M.
            • May 31, 1974
            • 8400
            go junkyarding. the 49 to 54 chevy pass cars will be suitable donor for yer lost nut.mike
            • Terry D.
              • May 31, 1987
              • 2696
              Mike
              I wish I could go junkyarding, with the price of steel up all of the junk yards in Northern Ohio have sent the old heavy cars to the furnace. If anyone knows of one in my area I would sure appreciate the where abouts!
                • 43247
                Originally posted by Terry Deusterman (11486)
                Mike
                Terry----
                If all else fails, McMaster-Carr #93839A840. This is a nut very similar in all respects to the original. It's a grade 8 piece. However, you'll need to buy 10, but they're less than a buck each. Don't use a hardware store nut unless you're CERTAIN it's grade 8. Most hardware store nuts of this size will be grade 2 or ungraded.
