Air Conditioning Compressor label - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Does anyone know where I can purchase a date coded compressor label for a '72 SB? Or in the alternative have my reproduction label properly daye codd?
    Jerry
  • Larry M.
    • January 1, 1992
    • 2702
    Re: Air Conditioning Compressor label
    Jerry:
    I do not know of any source for a (custom) date-coded air conditioning compressor label. My recommendation is to find someone with an old IBM electric typewriter and type in your own date. I still see a number of these typewriters in banks and credit unions, etc. I know they are still around. Many of these typewriters also have multiple font balls. Pick one that looks good, and practice a few times on a blank sheet of paper.
    I am not certain of the correct date code format for 1972. Your TIM&JG should tell you. For 1967, the format was MMDDYS. Example: 032172 is March 21, 1967, second shift. On my car, the compressor label date was approximately 7 weeks before the car build date.
    Larry
    • Robert C.
      • December 1, 1993
      • 1153
      Take your repro to a print shop with an example of the correct date-code font, size etc. and see if they will print it for you.
      With a little enginuity, ie; tape the label to an 81/2x 11 paper in just the right place and print it yourself on you own computer printer.
      • Chuck S.
        • April 1, 1992
        • 4668
        Originally posted by Jerome Pederson (46381)
        Does anyone know where I can purchase a date coded compressor label for a '72 SB? Or in the alternative have my reproduction label properly daye codd?...
        I have missed the opportunity to mention this a couple of times now, but better late than never: A couple of old wisened verterans told me once that if you HAVE the original compressor with the foil label, you can use a heat gun to CAREFULLY remove the label from the old compressor. I haven't tried this, but these individuals should know what they're talking about. You'll be far better off going this route than using a repro label.
        The more of these compressor label threads I read, the more obvious it becomes...any repro label is a compromise that will be discovered on the judging field.
