'58 Generator bracket mount - NCRS Discussion Boards
  • Susan G.
    • May 31, 2005
    • 136
    Does anyone know if the mount for the generator to the manifold is a two piece mount (plate and brace). Does it allow for front to rear adjustment to align pulleys? Thanks, Susan
  • Dan H.
    • July 31, 1977
    • 1369
    Re: '58 Generator bracket mount
    Hi Susan, what is the Vin number of your 58? Does it have the hood support on the passenger or driver side of hood. Both have different generator mounting methods. The alignment of the belts is determined by the pulley offset, the backing plate and 'U' shaped mount, all must match the particular style, early or late 58, simple huh? Early 58's have just a 'U' bracket and a heat shield bolted directly to the exhaust manifold, while later 58's have the 59 style plate, 'U' bracket, offset pulley etc.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Susan G.
      • May 31, 2005
      • 136
      Dan, we are a late build. Thanks for sharing your knowledge, very helpful in directing us forward. Fairly sure we now know what we need.
      Thanks again, Susan
      • Gary C.
        Administrator
        • October 1, 1982
        • 17693
        Susan, remember to use Clem Z's home made alignment tool of a 24 inch piece of 1/4 or 5/16 rod with a 6 inch bend for a handle. Lay across the generator pulley with the handle touching the side of the generator pulley to the water pump or crank pulley. If aligned the rod will stay in the grove, if not the rod touches the wall of the far pulley. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Susan G.
          • May 31, 2005
          • 136
          Gary, thanks for the advice, did not know this technique, will use when we get to that point. Thanks, Susan
          • Mike B.
            • November 1, 2004
            • 389
            Hi Susan,
            Glad to hear you are making progress!
            Mike
