66 BB Oil pressure gauge acting strange.... - NCRS Discussion Boards
  • Keith B.
    • August 12, 2007
    • 220
    Need help fellow members..........Had my cluster out for bulb replacement and cluster repaint after 4 months. Hooked everything back up this weekend, all the lights illuminate -great. But my oil pressure gauge (80lb) upon start-up and driving goes right over to end at 80LB, then upon idling it tapers back to 60-70LBs. I know I have not driving the car since summer but if my memory is correct it usually floated around 40-50LB mark. All I did was disconnect the brass fitting at the cluster and re-connect it. Is there a step I missed, air in the line, check the other end into the block, could the gauge now be faulty?? ( please don't make me take that cluster out again)......suggestions sincerely appreciated.
  • Chuck G.
    • May 31, 1982
    • 2034
    Re: 66 BB Oil pressure gauge acting strange....
    How cold was it when you fired it up?
    Chuck
    • Keith B.
      • August 12, 2007
      • 220
      It had not been started in 4 months, car is on a charger in a very heated garage. I drove it 2-3 miles and gauge still goes all the way over to 80LB when driving and down to 60LB when idiling.....still too high comparted to what I recall. Nothing else done to the oil line except un hook it and re-connect it, except the neddle was moved around a bit by hand when I cleaned the gauge face to get the dust/lint off it before re-installing the glass cluster..........
      • Mark L.
        • January 1, 1996
        • 121
        Same oil pressure gauge?
        Engine at operating temperature?
        High oil pressure at cold temperature is not unexpected.
        Low oil pressure while running is VERY bad no matter what temperature.
        • Michael H.
          • January 29, 2008
          • 7477
          Are you using the same type of oil in the engine?
