Bushing Kit and High Capacity Transmission Pan - NCRS Discussion Boards
  • Jeff C.
    • February 26, 2008
    • 8
    Hello, New here, first post, I have a '70 LS5 coupe and I need to replace suspension bushings and wonder if by NCRS standards can I use the better quality bushings that are avaialble and if so, can you point me in the right direction for purchase?
    In addition, can I put on an aluminum high capacity transmission pan and not lose points?
    • 43247
    Re: Bushing Kit and High Capacity Transmission Pan
    Jeff-----
    If by "better quality bushings" you mean polyurethane bushings, the answer is that the use of these is detectable and will undoubtedly result in loss of points in NCRS judging. Beyond that, I absolutely do not recommend the use of polyurethane bushings on a Corvette. You will end up with a harsher, more squeak-prone ride. Forget them. GM NEVER, EVER used polyurethane bushings on a Corvette.
    As far as the transmission pan goes, I fully expect that you'll lose points for such a pan if it's detected during judging. Since this sort of change is pretty easily detectable with just a glance under the car, I think you can be pretty sure it would be detected.
    • Jeff C.
      • February 26, 2008
      • 8
      Thanks Joe, That settles it then, OE bushings and pan. That's what I needed to hear.
        • 11668
        Also realize that there are replacement rubber bushings and "much more correct" reproduction bushings. Just buying rubber bushings doesn't necessarily get you "all the points."
        Patrick
          Jeff -
          You want the "correct" upper control arm bushings with 1/4" of rubber exposed past the small end of the outer shell - most of the vendors have them, but ask first.
          • Jeff C.
            • February 26, 2008
            • 8
            Thanks John, I'll be sure to check for that before ordering.
