'62 power windows question? - NCRS Discussion Boards
  • Paul B.
    • January 31, 2007
    • 313
    Hi,
    I did a search, but found nothing.
    My '62 JG says "They operate with the ignition in the on or off position" but mine work at all times including at LOCK?
    I checked the wiring diagram, and the windows get power directly from the battery terminal on the starter solenoid, nothing goes through the ignition switch etc...
    Paul
  • David S.
    Infrequent User
    • July 31, 1992
    • 8
    Re: '62 power windows question?
    On a 62 ignition switch there are only 3 positions off(lock), on, and start. As you correctly noted PW feed is hot at all times so they will operate independent of ignition switch.
    • Paul B.
      • January 31, 2007
      • 313
      Thanks for the reply David, but the '62 ignition switch does have LOCK, OFF, ON, START and thats why I wanted to be sure... Maybe the next edition could just say "power windows operable at all times independent of ignition switch"?
      Paul
      • David S.
        Infrequent User
        • July 31, 1992
        • 8
        Hmm thought only had 3 positions. Anyway internally it only switches 12 volts on to switched circuits and to solenoid in start position. hope this helps.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          Paul - Do you have a copy of the C1 Operations & PV Manual and have you reviewed that rascal? Also, if you follow your wiring for about 90 seconds, you will find that circuit is hot 24 hours a day unless the 40 amp breaker on the firewall trips or the battery is unhooked.
          • Paul B.
            • January 31, 2007
            • 313
            Thanks for the replies guys, much appreciated.
            I have the AIM, ST-12 and JG, but no Operations & PV? One more to add to the list I guess...
            As mentioned I had checked the diagram, I though maybe I was missing something.
            All the best,
            Paul
