Axle length measurement - NCRS Discussion Boards
  • Mike B.
    • November 1, 2004
    • 389
    From where is the axle length measured? The splined end is obvious but I am not sure from what point to measure on the bearing end.
    Thank you.
    Mike
  • Gary C.
    Administrator
    • October 1, 1982
    • 17769
    Re: Axle length measurement
    Mike, from the splined end to the outside (brake side)of the hub flange. Use a square on the flange end and hold the at the point on the square where it's equal to the hub. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Mike B.
      • November 1, 2004
      • 389
      Thanks Gary. I have the axles out for rear end work and while I am at it want to double check the lengths to spec.
      Mike
