here is a pic of the shielding that came off of my 70 lt1. i have replaced all these parts with nos parts. what is missing? what other shielding pieces do i need that are not pictured here? hope this pic works
70LT-1 shielding
Re: 70LT-1 shielding
I agree...four inner spark plug shields. Only the two rear outer covers, as shown, for late 70 shielding.
Mounting bracket hardware is available from vendors, and attach to block under 1/4-20 cap screws. From what I remember, they are simple 1/2"-5/8" wide angle brackets, chrome plated.- Top
Mike,
I probably will not do the best job at describing the mounting bracket things, but I think they are maybe 3/4" wide and a few inches long and bent/curved. I think they have a hole at each end, one for the wing bolt to thread into and another to mount them at other end (to block, I think).
The wing bolts are the easy part, but you can see a pic of the wing bolts on the auction site item # 260215625179- Top
Scott, that is not what I was thinking of (although those pieces are somewhat related since they hold the wires), I was referring to the pieces that hold the lower rear shiedling on the car.
Here is a pic that shows one side shielding with brackets and wing bolts includedAttached Files- Top
