70LT-1 shielding - NCRS Discussion Boards
70LT-1 shielding
  • Mike G.
    • July 31, 2002
    • 709
    70LT-1 shielding
    here is a pic of the shielding that came off of my 70 lt1. i have replaced all these parts with nos parts. what is missing? what other shielding pieces do i need that are not pictured here? hope this pic works
  • Mike G.
    • July 31, 2002
    • 709
    Re: 70LT-1 shielding
    i also have these
    • Brad M.
      • July 31, 2005
      • 262
      There are some small mounting brackets that hold the lower rear horizontal pieces (top items in your 1st pic) and the wing bolts.
      • Mike G.
        • July 31, 2002
        • 709
        what do they look like? thanks
        • Harmon C.
          • August 31, 1994
          • 3228
          I would have thought their was four of the inter spark plug shields and I only see three in the picture.
          Lyle
          Lyle
          • Mike G.
            • July 31, 2002
            • 709
            i thought so too so i bought 2 left and 2 right just in case. thanks
            • Chuck S.
              • April 1, 1992
              • 4668
              Lyle
              I agree...four inner spark plug shields. Only the two rear outer covers, as shown, for late 70 shielding.
              Mounting bracket hardware is available from vendors, and attach to block under 1/4-20 cap screws. From what I remember, they are simple 1/2"-5/8" wide angle brackets, chrome plated.
              • Mike G.
                • July 31, 2002
                • 709
                so thats all the chrome pieces? i thought i would need a couple more larger outer pieces. does anyone have a pic of the L brackets i need. i can get the wingnuts.
                • Brad M.
                  • July 31, 2005
                  • 262
                  Mike,
                  I probably will not do the best job at describing the mounting bracket things, but I think they are maybe 3/4" wide and a few inches long and bent/curved. I think they have a hole at each end, one for the wing bolt to thread into and another to mount them at other end (to block, I think).
                  The wing bolts are the easy part, but you can see a pic of the wing bolts on the auction site item # 260215625179
                  • Brad M.
                    • July 31, 2005
                    • 262
                    I agree with you guys that there should be four spark plug shields, thanks for covering for me not mentioning that part.
                    • Scott S.
                      • May 31, 2006
                      • 85
                      Here's one of them...
                      And there's a rubber grommet that fits into it to hold the s/p wires.
                      • Robert M.
                        • June 30, 1992
                        • 120
                        The 1970 AIM describes it very well.
                        Check through the AIM. The drawings will show every thing you need.
                        If you don't have the AIM, get one. It's hard to work on these cars without an AIM.
                        • Mike G.
                          • July 31, 2002
                          • 709
                          how many of those do i need? 1 each side?
                          • Mike G.
                            • July 31, 2002
                            • 709
                            i think i have those. i did not know what they were. i will look tonight. thanks for all the help.
                            • Brad M.
                              • July 31, 2005
                              • 262
                              Scott, that is not what I was thinking of (although those pieces are somewhat related since they hold the wires), I was referring to the pieces that hold the lower rear shiedling on the car.
                              Here is a pic that shows one side shielding with brackets and wing bolts included
