The following number (as close as I can tell) is stamped on the engine pad (small block) of my 66 coupe; CEA13829  "I" or "1" not sure.  Is it possible to decode this number to determine what the engine is from or what year it might be?  The intake casting number appears to be 3965577 indicating possibly a 70's vintage engine. Thanks much.
					66 coupe eng pad no.
	Tags: None
Re: 66 coupe eng pad no.
Most CE blocks were GM replacement block. Casting # for most small blocks in the 70's for Corvettes was 3970010. Check the casting date tag.The following number (as close as I can tell) is stamped on the engine pad (small block) of my 66 coupe; CEA13829 "I" or "1" not sure. Is it possible to decode this number to determine what the engine is from or what year it might be? The intake casting number appears to be 3965577 indicating possibly a 70's vintage engine. Thanks much.
KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
