C1 Custom frames - NCRS Discussion Boards
C1 Custom frames
  • Justin B.
    • March 1, 1996
    • 478
    Re: C1 Custom frames
    Does Billy have a website or a contact number??
    • Justin B.
      • March 1, 1996
      • 478
      • Justin B.
        • March 1, 1996
        • 478
        #18
        John, Hats off to your 59'!! That looks like a lot of fun!!! Justin
        • Justin B.
          • March 1, 1996
          • 478
          #19
          • Loren Smith
            #20
            Re: C1 Custom frames *NM*
            • Loren Smith
              #21
              • David B.
                • July 31, 2004
                • 330
                #22
                http://www.corvettecorrection.com/index.html
                Dave, 1969 427, 1957
                Previous: 1968 427, 1973 454
                • David B.
                  • July 31, 2004
                  • 330
                  #23
                  • Loren S.
                    • November 1, 2002
                    • 172
                    #24
                    Originally posted by Mike Mccagh #14
                    if i had to do it all over again, i'd do it the same way i did in the mid-90's. get a donor c-4 with good frame and floorpan and firewall then fabricate this assembly to accept a c-1 windshield, door/trunk/hood hinges and then bond a c-1 front clip(repo one piece) , rear clip repo panels to the c-4 set-up. you'll need used doors and repo hood and trunk. see Restorer article about 2000 titled the ideal corvette.This approach allows use of all the c-4 interior items(Bose, air cond etc) and it was way less costly than a Paul Newman type modified c-1 frame that accepts c-4 front and rear suspensions.one can buy a "worn out" c-4 for about 2K , use its drivetrain and interior after tweaking them. mike
                    Mike - I read your article on the Restorer CD - very neat stuff. Could this rebody be done about as easily on a C5 donor car? Isn't the C5 wheelbase and width a closer match to the C1 than the C4?
                    • Mike M.
                      • May 31, 1974
                      • 8381
                      #25
                      as far as widths go, the c-4 dash pad neded 3/8" removed from each side to mate to the c-1 windshield. as far as wheelbases go, i had to move the c-1 wheel openings 6" closer together(the rear 1/4 panel had to be centered 4" foreward of its original position and the front side panel had to be centered 2" rearward) to accomidate the c-4 stock wheelbase. can't recall for certain but seem to recall the c-1 wheelbase is 102" and the c-4 wheelbase is 96". don't have clue about the c-5 wheelbase but would suspect its similar or identical to theat of the c-4.mike
                      • Loren S.
                        • November 1, 2002
                        • 172
                        #26
                        61 C1: 102 wheelbase, 70.5 width, 177.2 length, 57 front track, 59 rear track.
                        C4: 96.2 wheelbase, 70.7 width, 178.2 length, 57.7 front tread, 59.1 rear tread
                        C5: 104.5 wheelbase, 73.6 width, 179.7 length, 62 front track, 62.1 rear track
                        • Mike M.
                          • May 31, 1974
                          • 8381
                          #27
                          looks like using a c-5 floorpan/frame would negate the need top re-position the c-1 wheelwells but if one were to use the c-5 wheels, they may well interfere with the c-1 quarter panels . it'd be a trial and error experiment. go for it and write an article.mike
                          • Loren S.
                            • November 1, 2002
                            • 172
                            #28
                            A more involved alternative would be to stretch the width of the body an inch and a half on each side, probably just inside the fenders both front and back. Then you would have to do some surgery on the bumpers to widen them as well.
                            • Edward M.
                              • November 1, 1985
                              • 1916
                              #29
                              Might also want to take a look at Tray Walden's Street Shop in North Alabama. Quality operation.
                              • Joe G.
                                • January 11, 2016
                                • 134
                                #30
                                Chassis Concepts: www.chassisconcepts.com
                                Corvette Correction: www.corvettecorrection.com
