67 wing windows revisited - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    I saw a post earlier today about 'sloppiness' in the vent window mechanism. My driver's side window has free-play, but it is also hard to turn for the last quarter-inch before closing. Rebuild the mechanism, or is there another issue? Thanks.
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 67 wing windows revisited
    Rebuild or replace with a new repro.
    • Stephen L.
      • May 31, 1984
      • 3162
      • Joe R.
        • March 1, 2002
        • 1356
        Another possible cause for being hard to turn for the last quarter inch is if the window does not fit properly in the rubber weather stripping. One of my vent windows has this problem and the window sort of "pops" as it seats when being closed.
        This is just another thing to check, but if you also have a lot of free play you may as well rebuild the regulator.
        • Joe R.
          • March 1, 2002
          • 1356
          • Gerard F.
            • June 30, 2004
            • 3806
            Larry,
            Try a light coat of this stuff on the weatherstipping:
            http://img80.imageshack.us/img80/743/silglydesmallvi8.jpg
            Worked on mine for that last hard quarter turn.
            Also great for a tach/speedo cable lubricant.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
            • Gerard F.
              • June 30, 2004
              • 3806
              Larry,
              Jerry Fuccillo
              #42179
              Jerry Fuccillo
              • Walt W.
                • November 1, 1998
                • 92
                Larry,
                I put up the post earlier in the week. I have found excellent articles from the Restorer from spring of 1990 and 1998. They give detailed procedures
                on repairing or rebuilding the vent window with pictures.
                Walt Wems
                • Walt W.
                  • November 1, 1998
                  • 92
                  Larry,
                  Walt Wems
