65 rear diff stamping ????? - NCRS Discussion Boards
  • Donald S.
    • January 23, 2008
    • 183
    my 65 diff has the following -----AU 6 4 65 ------ and nothing else the case was cast 04 of 65 ---- according to the by the #s book it should not have a 65 and it should have a W for warren and a E for eaton where the 65 which is correct ????? my stamping looks to be correct but ????? please help...
  • Donald S.
    • January 23, 2008
    • 183
    Re: 65 rear diff stamping ?????
    here is a pic of the stamping ....
    • Donald S.
      • January 23, 2008
      • 183
      • Timothy B.
        • April 30, 1983
        • 5196
        Donald,
        In 1963/64 the rear is stamped like yours so I would say it's fine and probably made before the newer stamping with the W started.
        • Timothy B.
          • April 30, 1983
          • 5196
          Donald,
          • Rich Puleo
            In my experience I'd have to say this is fine, I'd like to check the casting date on the side of the pumpkin case & also the cover plate. They are usually hard to read. When I'm home later I'll dig for some pics, I'm sure I have some to compare.
            Rich
            • Rich Puleo
              Rich
              • Donald S.
                • January 23, 2008
                • 183
                Re: 65 rear diff date code
                heres the casting date code ..rich.... thanks
                • Donald S.
                  • January 23, 2008
                  • 183
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    Your stamp format looks good to me
                    Donald -- I don't believe the W and the E's that Colvin describes started before 1968 or later.
                    Here's the bottom stamp from a mid-67 BB (12800 VIN range).
                    And here's a link to the top edge code stamp, which you should also see on your 396 rear.
                    http://i47.photobucket.com/albums/f173/peterwspics/Top67carrierCustom.jpg
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      • Donald S.
                        • January 23, 2008
                        • 183
                        thanks for the conformation *NM* *NM*
                        • Donald S.
                          • January 23, 2008
                          • 183
                          • Rick S.
                            • January 1, 2003
                            • 1203
                            Re: Your stamp format looks good to me
                            Here is the date code on my 67, VIN:21135.
                            • Rick S.
                              • January 1, 2003
                              • 1203
