TCS (72) LT1 - NCRS Discussion Boards
TCS (72) LT1
  • Rob C.
    • August 31, 2004
    • 144
    TCS (72) LT1
    Could some one tell me what is the correct name for the solinoid that goes in the transmition and were can I find one.
    Thank You,
    Rob
    • 11698
    Re: TCS (72) LT1
    Rob,
    The switch for the transmission is available on eBay on a regular basis. I suspect that some of the catalog vendors "may" have it as well. Search "TCS switch."
    I swiped the pic below from ebay. You need the pin connector.
    Patrick
      • 11698
      Re: TCS (72) LT1
      Rob,
      Patrick
      • Brad M.
        • July 31, 2005
        • 262
        Re: TCS (72) LT1
        Also the GM part number is 3961567. The one in pic above is the current service replacement version. The original version, to the best of my knowledge, had white/off white in the area where this one is black.
        • Brad M.
          • July 31, 2005
          • 262
          Re: TCS (72) LT1
          • Rob C.
            • August 31, 2004
            • 144
            Re: TCS (72) LT1
            Thank You.
            • Rob C.
              • August 31, 2004
              • 144
              Re: TCS (72) LT1
              Thank You.
