57 Crank Balancer Pulley - NCRS Discussion Boards
  • Marc W.
    • February 1, 2005
    • 53
    Did the 283ci,270hp 2x4 (July 57) Corvettes come from the factory with a riveted pulley 3/8 belt groove? Or did they come with a "deep ride" 1/2 inch belt groove? If they came with the "deep ride" 1/2 inch pulley was it riveted on or a separate bolt-on?
    • May 31, 1974
    • 8383
    Re: 57 Crank Balancer Pulley
    early, mid or late vin#?mike
      • May 31, 1974
      • 8383
      • Marc W.
        • February 1, 2005
        • 53
        July 9,1957 = Vin# E57S105091
        • Marc W.
          • February 1, 2005
          • 53
            • May 31, 1974
            • 8383
            i'd look for a bolt on harmonic balancer BUT you'll probably need the deep groove pulley. i used a deep groove , bolt on pulley on vin 4450, but the riveted pulley/balancer combo on vin 1093.both FI's and both took the deep groove pulley. bolt on harmonic balancers plentiful but the correct deep groove pulley will be elusive, and expensive. good luck,mike
              • May 31, 1974
              • 8383
                My '57 270 #4275 had the bolted-on crank pulley.
                    • May 31, 1974
                    • 8383
                    deep groove pulley too, john?
                      • May 31, 1974
                      • 8383
                        Yup - deep-groove pulley too.
