Help identify this door - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 675
    I've been hauling around this door for over 40 years now and I pulled it out of storage to try and identify what year it is. A distinguishing feature is the recessed area around the door lock pull mechanism. Is it a 59-60 or perhaps a 1961? I know that 1961 and 1962 doors were about an inch longer. This measures about 32" along the top of the door along the reveal area from front to rear.
    You do not have permission to view this gallery.
    This gallery has 4 photos.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Curt R.
    • February 1, 2004
    • 41
    It has no holes for spears, so it's either a '56 or '57 door.
    • Keith R.
      • August 31, 2001
      • 675
      Hey Curt! Thanks for chiming in. Was the '59 you're working on a COPO? Did it come with spears in the doors? 1960_chevrolet_corvette_1960_chevrolet_corvette_19d8320b-0749-4f85-962b-c0b20d85faca-TTh9oD-16826-16827-scaled.jpg
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Curt R.
        • February 1, 2004
        • 41
        Brain F..t sorry !
        • Gary C.
          Administrator
          • October 1, 1982
          • 17928
          Keith,
          Look for rivets on the underneath side of the door. Late '57's added metal re-enforces to keep doors from saging.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Gary C.
            Administrator
            • October 1, 1982
            • 17928
            Keith,
            1957 door mid year before anti sag metal reinforcements added.
            Gary
            NCRS Texas Chapter
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11363
              Keith, This thread(below) over at CF talks about that door latch on a 61, which cannot be removed without cutting the rain cover(half moon).
              Can your latch be removed?
              Also in the thread, there are photos of the rain guard of various years, shown from the inside. It may help identify your door.
              https://www.corvetteforum.com/forums...-in-place.html
              • Keith R.
                • August 31, 2001
                • 675
                Originally posted by Gary Chesnut (5895)
                Keith,
                Gary
                It definitely has the rivets Gary and the metal reinforcements inside. C1door13.jpg
                Keith MacRae
                NCRS #36692
                New Mexico Chapter
                1960 290HP FI
                • Keith R.
                  • August 31, 2001
                  • 675
                  Another notable difference is the area behind the door release stem is located. On the photo of the '57 door you posted, the fiberglass cut-out behind the stem is rectangular with no recess. On mine, it's a larger, more oval shape and is recessed.C1door6.jpg
                  Keith MacRae
                  NCRS #36692
                  New Mexico Chapter
                  1960 290HP FI
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11363
                    Keith, Can you get a few photos of the backside of the rain guard behind the latch. ​​​​Compare it to that thread I referenced, which is a 61.
                    Rich
                    • Keith R.
                      • August 31, 2001
                      • 675
                      Keith, Can you get a few photos of the backside of the rain guard behind the latch. ​​​Compare it to that thread I referenced, which is a 61.
                      Rich
                      Thanks Rich. I took some photos of the interior of the release mechanism and the rain guard and looked at the other photos on the CF thread particularly of the '59 and '60. I presume that my door is a '59 or '60 as it has the release mechanism mounted lower than the '57 or '58 as noted in other posts and it is shorter than a '61 at approximatly 31 1/2" as measured along the window garnish line. Of interest is the photo of the '61 showing the final photo. It almost appears that there is a flange around the rain guard when compared to mine which might suggest that the rain guard was installed from the outside of the panel before being bonded to the door. Attached are photos comparing the two. C1door6.jpg 61 door release.jpg
                      Keith MacRae
                      NCRS #36692
                      New Mexico Chapter
                      1960 290HP FI
                      • Keith R.
                        • August 31, 2001
                        • 675
                        Here are the photos of the rain guard and release mechanism as taken from the inside of the door. Doorrelease1.jpg Doorrelease3.jpg Doorrelease2.jpg
                        Keith MacRae
                        NCRS #36692
                        New Mexico Chapter
                        1960 290HP FI
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11363
                          Keith, That 61 photo, appearing like the guard was attached from the inward side of the door, is a optical issusion.
                          Here it is after he cut the hole to remove the lever. It was bonded on the inside.
                          If you can remove your lever assembly, it is either 59 or 60. 61/62 requires a hole cut to remove it.
                          Rich
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11363
                            Here are '59 doors(March build)
                            Pass side
                            Driver side(blurry, but best I had) Notice the oval hole for the lever. Much smaller than yours.
                            Here is your door.(Driver side) I don't think it's a 59 door.
                            59 and earlier doors had upper reveal retainers for the outer garnish moldings. Small screws held the molding from the inside.(window must be removed to attach the moldings to the retainers) Does your door have these retainers, or evidence of them previously installed? Later doors didn't use these retainers, as different molding were used with 2 T-bolts to hold the outer garnish.
                            • Keith R.
                              • August 31, 2001
                              • 675
                              I didn't realize that the '59's had a different method of retaining the garnish molding - my door does not have the retainers in place but I will look for evidence that they may have been installed. From the photos you posted, it appears that the March '59 door didn't have a rain guard installed either. I wonder when they began installing them? I'll try to remove the door release assembly and see if that can be done easily. I think that the most distinguishing feature is that my door is not as long as the '61 which I understand measured approximately 33 1/2" long. So at this point, I know that its not a '57, '58, '61 and certainly not a '62 but we're narrowing it down. Thanks again for your inputs Rich.
                              Keith MacRae
                              NCRS #36692
                              New Mexico Chapter
                              1960 290HP FI
