Tripower Base Tabs Breakage - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    The 67-69 tripower air cleaner base tabs to bolt it to the outer carbs seems like a bad design. My last car one tab was already broke off and I noticed my current one a tab has a lot of play. Seems like a bad design not to have those tabs sitting flush on the carbs. Or am I missing something? I have not seen any mention of a spacer so when you tighten the bolt even slightly it starts to bend the tab down since it's not making direct contact with the bolt hole area of the carb.
    TIA,
    Jack
    Jack Ottofaro
  • Joseph W.
    • February 20, 2022
    • 380
    Better question is how do you fix it? I have a base with a broken tab too.
    1971 coupe LS5 454/365hp
    1969 coupe L71 427/435hp
    1969 coupe L89 427/435hp
    • Jack O.
      • July 31, 1996
      • 527
      It's spot welded on so if you're lucky enough to have the tab you could probably get it repaired. However if you choose to bolt it on the same thing may occur again. I have the correct bolts but am hesitant to bolt it down since I noticed one of the tabs is loose. And I'm afraid if I don't tighten them enough they may vibrate out.
      Jack Ottofaro
