1962 Speedometer meltdown - NCRS Discussion Boards
  • Kenneth F.
    • September 30, 1988
    • 285
    As the odometer on my '62 was rolling to 50,000, the odometer stopped working and the speedometer needle action became erratic. Does this mean I will be removing the instrument cluster to have the speedometer-odometer mechanism repaired?
    Should I need to have the speedometer repaired can someone recommend a shop?
    Thank you,
    Ken
  • Mike M.
    • May 31, 1974
    • 8408
    corvette specialties of Maryland west. Brian tillus owner. mike
    • Keith M.
      • January 17, 2021
      • 695
      They have mine from my 69 right now. Tach, speedo, clock. About 8 week turnaround right now.
      late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
      • David M.
        • September 30, 2004
        • 533
        While I wont talk you out of restoring your 63/64 year old speedo, you may want to Inspect the cable to see if its all wadded up on either end.
        They do dry out and fail. Could be just a bad cable.
        Several vendors offer USA made replacement cables. Let me know if you need that info.
        • Kenneth F.
          • 285
          David, Keith and Mike,
          I will disconnect the cable from the speedometer and see if it is rotating when the car is driven. If it only needs a cable that would be fine.
          I really appreciate all of your information.
          Ken
