Texas Lone Star Regional - NCRS Discussion Boards
This is a sticky topic.
  • Don H.
    Moderator
    • June 16, 2009
    • 2268
    Mike,, I don't expect to ever own any C8 Corvette, let alone a Z06, but, there is this new fangled thing out there called AI. I asked AI where the battery is on a 2025 Z06 and here is what I learned....
    ​​​​​The 2025 Corvette Z06 (C8 generation) has its main 12-volt battery located in the front trunk (frunk). To access it, you must first open the frunk by pulling the release loop twice from inside the cabin, then remove a central plastic panel and two side trim pieces to reveal the battery underneath.​
    I dug a little deeper and asked about losing settings if battery is disconnected and AI said not to worry, only the windows need to re-indexed.
    So, I think your OK,
    And, I love this AI thing.
    • Michael J.
      • January 27, 2009
      • 7139
      Thanks, you saved me some time looking through the owners manual!
      • Gary C.
        Administrator
        • October 1, 1982
        • 17768
        Mike,
        FYI - read there are remote control battery disconnect devices available for C8's.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Michael J.
          • January 27, 2009
          • 7139
          Thanks, after watching the video of all the panels that have to be removed and put back on to even get to the battery, remote control would be the only practical way to do this.
          • Ken R.
            • August 31, 1980
            • 308
            I have been watching this developing, so my concern is getting the gas tank level to below 1/4 as well as the battery disconnection. Will have to do some talking with Roy or someone as to what open judging is really about? I have been talking with some corvette owners (most have C7 or C8) here in my town about our show. They mainly will do one day shows (Sat) with no interest in having their car inside from Thursday to Sat. afternoon with motel costs.
            And don't forget the frunk: if someone closes it with the battery disconnected, you will have to get into the car to pull the cable to get the frunk unlatched. As well as using the key to manually unlock the car door if someone locks it by mistake. Keep the top down may be the solution.
            Remote Battery Disconnect Switch - CorvetteForum - Chevrolet Corvette Forum Discussion
            • Michael J.
              • January 27, 2009
              • 7139
              I drove my C8 to the Glendale Regional in May and put it in Sportsman. It not too hard to manage the 1/4 tank if you watch your mileage. In Glendale, there was an exemption for C8s on battery shutoffs. I think that could be done most anywhere if they try.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17768
                Michael,
                FWIW, sorry, but the International Fire Code which all indoor venues subscribe to does not provide any exemption for C8's.
                Gary
                NCRS Texas Chapter
                • Michael J.
                  • January 27, 2009
                  • 7139
                  Well, I guess the Glendale facility doesn't follow that code. Which was good.
                    • 15609
                    #24
                    Yes, I saw that in the Restorer, and since I have already registered for the Lone Star Regional with no car entered, I am now wondering how to hook up a battery shut off switch since in my 2025 Z06, I don't even know where the battery is........
                    And will shutting down the battery mean everything would have to be reprogramed in the car?
                    I'll have to research this...but, see you all at the National.
                    Mike,
                    I have displayed my C8 at several indoor events and have never disconnected the battery. I may regret posting this but leave it connected and avoid setting off the alarm. Opening the doors or hatches normally lights everything, as you no doubt know, so be judicious doing that as well. Ask me how I know.
                    Search You Tube for videos of C8 battery service. I tried to get links to them but couldn't get transferable links (All of them came up from Bing and I couldn't get transferrable links) from my laptop in a hotel in Bowling Green. I would have made a video yesterday or Thursday, but this evening (Saturday August 30) the party is over, and I am not going to take the C8 apart in the motel parking lot - unless it won't start tomorrow for the trip home. One of these videos includes instruction of how to access some C8s that have a dead battery, but the one I saw has parts of it that are not applicable to my 2023 or your 2025. Neither of us have a hidden key behind the rear license plate, so access to the rear compartment with a dead battery requires drilling a hole behind the license plate. Don't panic -- with a dead battery you & I can use a key in the hidden key slot behind the driver's door and mechanically open the driver's door and access the front trunk through the mechanical wire under the dash on the driver's side. It is wise to try this before the battery is dead and one needs to execute the procedure under stress. And if you don't know where this hidden lock is, more You Tube videos will reveal it. It is hidden only because the designers believe the door lock(s) do not look compatible with the flow of the design of the car. How do I know what they think? I have heard them say it here in Bowling Green.
                    There are several videos on You Tube showing access to the battery in the front trunk (I hate the alternate word for that area). It is close to the windshield in this compartment. Search out those videos. It is good to see the battery access in case worse comes to worse. Museum Delivery includes a demonstration of access to the battery. It also contains a demonstration of access to the car with a dead battery. But for you that ship has sailed. I doubt many dealers go into this detail on their Corvette deliveries, but then the usual Corvette salesmen may not know these procedures either.
                    I am willing to hold a class on this subject, but at this time I cannot attend an event more than a day's drive from home. Sadly, that leaves you out of my reach. I hope the You Tube videos work for you. I will try to get links, if possible, from my PC when I get home and recover from this trip. That may be no sooner than later Monday.
                    • Ken R.
                      • August 31, 1980
                      • 308
                      #25
                      Not to hijack Terry's post; here is a video showing what Terry is discussing. Hope your trip is going well.
                      C8 Corvette - Dead Battery Guide
                        • 15609
                        #26
                        Well done Ken. Thanks.
                        I posted late last night and couldn't figure out that one. I don't know if there is roon for a battery cut off switch in there. I carry a ten mm nut driver to disconnect the battery terminal but have never had to use it. I also carry a battery jump box (the latest compact one), tow hooks for each end of the car and plastic pry tool to remove the tow hook covers in the facias. (Tow hooks for C8s are a whole other subject.)
                        At a meet if one is required to disconnect the C8 battery the easiest course of action would be to open the doors and both trunks before disconnecting the battery. Then leave them open for the duration of the meet and hope no well-meaning person comes along and closes them for you. Of course that raises security issues that would have to be considered.
                        Off to the highway
                        • Ken R.
                          • August 31, 1980
                          • 308
                          #27
                          I agree; if I disconnect the battery I am going to have everything open and hope it stays open. I also have the equipment Terry has to handle a dead battery. The other problem is that the car is locked in park with a dead battery. There is a special tool to get the car into neutral, but that is a pain to access also. Safe trip home.
                          • Michael J.
                            • January 27, 2009
                            • 7139
                            #28
                            Yes, after watching all the videos, and reading the warnings about the battery being out or down, far too much trouble and risk for me. Maybe if the judging is outdoors I will try it unless the C8 gets a special dispensation......
                              • 15609
                              #29
                              I am sorry that all this learning has scared you off Mike. I don't think it is as bad as the internet worry Worts would have you believe. I wish I could be there to help.
                              At this point we don't even know what "Open Class" will require, or at least I don't. So all the concern might be premature. I will be watching to find out the details of the new class.
                              My thanks to the administrators for pulling this topic out of the larger issue of the Frisco Meet. And thanks to Ken for posting the link to the C8 battery. No problems on the road, Ken. Light traffic and loads of fun with the C8. As I told someone in Bowling Green - it is not your grandfather's Corvette. Everyone, enjoy Las Vegas, the road tours, and best of luck to all.
                              • Michael J.
                                • January 27, 2009
                                • 7139
                                #30
                                Thanks Terry, I will check out how the judging works and take another look when I am feeling more energized to try something different. We get kinda spoiled by working for many years on such simple electronic machines as a C2, and ignore how the new cars are more like a complex sealed system not for user intervention.
                                I will need some luck in 'Vegas, as once again I am entering 3 cars for judging, so will get my exercise at the very least, jockeying the cars around at different times and spots. Hope it is not too hot, and I am sorry to miss the Texas Road Tour this year, after so many I have been on it. But I do suspect everyone will have a great time, and then on to Frisco!
