'64 water pump - NCRS Discussion Boards
'64 water pump
  • Richard S.
    • February 1, 1984
    • 85
    '64 water pump
    Morning.....In regards to a '64 with a final build date of April 30, should a 250hp require the 3782608 pump to have a date on the casting? Is that the correct pump for this application?
    Ric
    • 43271
    Ric
    Ric-----
    The GM #3782608 is the correct casting waterpump for your application.
    Dating for the '608' waterpump began in March, 1964. So, I think yours could go either way. Mostly, it would probably depend on the engine assembly date. However, If you could find a casting with a date consistent with your engine assembly date, that pump could have been installed on your engine.
    • Richard S.
      • February 1, 1984
      • 85
      Thanks for the info Joe, since it could be either date or no date I think I will go with no date then I don't need to find a very early pump. Do you know if these pumps had hex head bolts or slots on the back cover?
      Ric
      • Thomas R.
        • October 17, 2011
        • 78
        You do not know; how many none dated pumps were available to use beginning in March of 64. The pumps may have lasted for several later months. This is a good question for the j63/64 Judging group. Here are a couple photos of an undated 608 for 250/300 HP engine.
        You do not have permission to view this gallery.
        This gallery has 3 photos.
        • Richard S.
          • February 1, 1984
          • 85
          Thank you for the pics, answers the question about the bolts that secure the back plate. One more question, the nipple for the heater hose should it be a short or a long one for a '64 with A/C?
          Ric
