63 Corvette Belts and Pulleys issue! - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 819
    My 63 has the wrong water pump pulley on it so in an effort to correct it. I purchased what I thought was the correct W/P pulley 3770245 which is larger than the 6 inch currently on there. It already appears to have the correct crank, idler pulley, water pump repro belt as replacements are the exact same size. The idler pulley looks like 3 3/4. What am I doing wrong Belt is 15375 or I believe 37.5 inches. It looks like an inch short. HELP! I'm about to put the wrong pulley back on.
  • Harry S.
    • July 31, 2002
    • 5316
    Bob, I came up with 3840463 for the water pump. Probably not correct as somewhere in the description it mentions C60.
    I'll keep looking.
    • Bob H.
      • July 31, 2000
      • 819
      supposedly, GM 3843164 is correct original but it shows as 37.5 inches which is what I have
        • 43238
        Bob-----
        You don't say what engine you have and you don't say whether the car has power steering or air conditioning. All of these things matter as far as determining correct pulleys and belts.
        • Bob H.
          • July 31, 2000
          • 819
          Hi Joe. I mentioned the idler pully. 327/360. The idler is 3 and 3/4, the water pump pulley (02456) is just over 8 inches and it looks like the crank pully is 7 inches. Is something wrong with one of them?
          • Timothy B.
            • April 30, 1983
            • 5188
            Bob,
            The crankshaft pulley should be deep groove and part number end in 533. If everything lines up normal and it's just the reproduction belt that's where I would look for the problem.
              • 43238
              Bob------
              Yes, I should have deduced that you were talking about a 340 or 360 hp application because of the idler pulley.
              The correct pulleys are as follows:
              balancer--------GM #3766987 (original pulley) replaced by 8/64 by GM #3858533. Both pulleys are 6-3/4" OD
              waterpump------GM #3770245 7-1/8" OD
              idler assembly----GM #3829191 (consists of pulley, bracket, & bearing)
              • Bob H.
                • July 31, 2000
                • 819
                Thanks guys. I am going to talk with Quanta tomorrow now that I know pulleys are correct. The belt is close to fitting but want to see some adjustment
