Steering column seals - NCRS Discussion Boards
  • Frank C.
    • March 1, 1977
    • 70
    I'm about to install my steering column. Have successfully dry run it with the exhaust manifold, generator, dipstick and dipstick tube, removed and the LH dash insulator and e-brake handle loose. But installation of the hard rubber seal that seals the mast jacket to the front of dash is difficult. There is a nubbin that secures the directional signal bowl that interferes with the close fitting seal. I'm afraid that if I try to drive it down the column it'll damage the seal. I have protective masking tape on the column. That isn't helping the seal installation either. Comments? Help?
  • Terry D.
    • May 31, 1987
    • 2697
    Might help to know what year you are working on.
    • Frank C.
      • March 1, 1977
      • 70
      Update! The masking tape made all the difference. I removed it and wiggled the seal down. No damage to the seal on my C1 steering column. Frank
      • Gary C.
        Administrator
        • October 1, 1982
        • 17865
        Frank,
        The old trick on rubber bushings/grommets/moldings is to lightly lubricate with dish soap, which will not harm the rubber.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
