Recommended manufacturer for Soft Top for 60 Vette - NCRS Discussion Boards
  • Scott S.
    • January 1, 2005
    • 30
    Hi all.
    I'm going to replace the soft top on my 1960. Any particular manufacturer you have had success with?
    Regards and Thank!
    Scott Scearce
    Tallahassee, FL
  • Mike M.
    • May 31, 1974
    • 8402
    al knock in el paso texas. buy his installation video if you've never installed a top on. a c1. mike
    • Scott S.
      • January 1, 2005
      • 30
      Regards Mike
      • David H.
        • June 30, 2001
        • 1545
        Scott
        +1 on Mike's comment.
        Have you by chance replaced your windshield? Some replacement glass is a bit thinner than original. If your new top is too tight, you run a risk of pulling off header on glass.
        I think Al Knoch has a cut that gives you a little more room.
        Dave
        • Mike M.
          • May 31, 1974
          • 8402
          Originally posted by David Houlihan (36425)
          Scott
          Dave
          Dave is correct regarding replacement windshields. If so, I'd use an epoxy window bedding that secures the glass to the weatherstrip. the glass is near impossible to dislodge the glass from the rubber with the epoxy sealants. mike
          • Scott S.
            • January 1, 2005
            • 30
            Scott
            Dave
            Hi David.
            Thanks for the reply. Sure enough on the windshield replacement! Had it replaced and not long afterward I had the windshied pull from the frame. Top was vinyl and had shrunk quite a bit from not having it up as a habit, but yes it was right after the replacement. I am getting a new top which will be canvas from Al Knoch and I will always have it in place even though canvas shrinks less. $445 for the new top by the way.
            Scott
            • Terry D.
              • May 31, 1987
              • 2696
              If you do have it down for awhile, park it the sun, not latched, and let it warm up a few hours before you latch it>
