1963 Trailing Arm Shims Loose & One Missing - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 458
    During my inspection of the rear suspension components, I noticed a missing shim on the outboard side of the passenger side trailing arm and the remaining two outboard shims are loose (inboard side shims still tight). The bushings on both arms need replacing as well (I have the bushings). I can only guess how difficult it is going to be in finding original shims (I didn't see anything repro that's close to correct). If anyone has some that they would be willing to part with (PM me) or know of other sources, please let me know (none of the repros I see are correct).
    Fred
  • Larry M.
    • January 1, 1992
    • 2701
    Fred:
    Are your TA shims the original OEM "slotted", or the "two-hole" ones used on most C2 cars. I assume the former, but confirm.
    Bair's may be a good place to check. Also a search by GM part number on Ebay and internet.
    Many folks used the C3 slotted shims and just call it "good enough". The C3 slotted shims are the easiest to install and work with.
    Larry
    • Frederick H.
      • August 31, 1983
      • 458
      Thanks Larry. Yep, mine are the original slotted ones. I will check with Bair's tomorrow - did notice that Davies Corvette Parts and Zip show a close repro that may have to do. I'm hoping I can install the shim(s) without any disassembly and get things tight enough to drive it to the shop to get the bushings installed and alignment done.
      Fred
      • Frederick H.
        • August 31, 1983
        • 458
        By the way, how the heck do you get to the nut to properly torque it to the 40-60lbs per the shop manual with the car on the ground?
        • Larry M.
          • January 1, 1992
          • 2701
          Fred:
          You bring up a good question.
          1. I was not certain that my cadmium replated OEM bolt would take the full torque, so I stopped at round 35-40 ft lbs as best I remember. That was 20 years ago. But my 67 car also had the two-hole shims, and I knew that they could not fall out.
          2. I believe I jacked up each trailing arm to their "normal ride height" without the wheels in place. Used two jacks. Then torqued the bolts...........which were now much more accessible.
          Larry
          • Frederick H.
            • August 31, 1983
            • 458
            Ah, ok. Might try jacking up the arms as you described just to keep the existing shims in place well enough to drive it to the shop.
            Thanks.
            • Larry M.
              • January 1, 1992
              • 2701
              Corvette Central advertises for OEM TA shims for 1963 cars. https://www.corvettecentral.com/c2-63-67/suspension/rear-control-trailing-arm/63-rear-trailing-control-arm-shims-set-correct-20-582097?srsltid=AfmBOortqivXOcTdh2ORfCp8ONMoXCl14iD u9zwN389bhouVJ6MMRe80
              Using the slotted 69-82 shims should work to get you to the alignment shop. They are easy to source and install.
              Larry
              • Frederick H.
                • August 31, 1983
                • 458
                Thanks Larry - just ordered!
                • Douglas C.
                  • September 30, 1988
                  • 237
                  Just a pic of an original '63 TA shim compared to the repros currently available.
                    • 15706
                    The primary reason why shims fall out is improper installation. The last shim, a thick one, should be a slight interference fit that requires tapping in with a small hammer to seat. Then, with the car at normal ride height, torque the nut to spec.
                    Shimming is best done with the car on a drive-on lift. If the car has "captured" shims, use a pole jack to lift the spring enough to remove the link bolt, then the training arm bolt can be removed to reset the shim pack. Once set remove the pole jack, bounce the car up and own a few times and torque the nut.
                    • Frederick H.
                      • August 31, 1983
                      • 458
                      Thanks Duke. I am also having the shop replace the trailing arm bushings.
                      Fred
