1965 alternator - NCRS Discussion Boards
1965 alternator
  • Roger H.
    • September 27, 2020
    • 87
    1965 alternator
    My original alternator needs rebuilding or replacement. Does anyone have any suggestions for a good replacement or a reputable place to have it rebuilt? Thanks.
    • 43218
    Roger----
    Alternator restorers/rebuilders advertise in the Driveline.
    If you have a modicum or mechanical ability, you can rebuild the alternator yourself. It's really quite easy and no special tools are required. The complete procedure can be found in the 1965 Chevrolet Overhaul Manual.
    • David H.
      • June 30, 2001
      • 1526
      Originally posted by Joe Lucia
      ... you can rebuild the alternator yourself...
      +1
      Roger
      As Joe said, pretty straight forward.
      Dave
      • Leif A.
        • August 31, 1997
        • 3627
        Roger,
        To answer your question, Ken Bruno Motorsports is a terrific resource to get, both, alternators and starters rebuilt/restored to better than original specs. All diodes are correctly date stamped and all are rebuilt to 70 Amp specs. He has done several for me over the years and they always come back looking and working beautifully.
        We specialize in Corvette and other GM Muscle Car Show Quality Delco Alternator, Starter and Generator Restorations.
        Leif
        • Roger H.
          • 87
          Thanks to all who responded. This is just what I was hoping to find. I will be contacting Ken Bruno soon. I've been driving my '65 for fifty-two years, and some of the original parts are in need of repair. It's good to know I can keep the originals.
            • 15667
            Roger----
            The two governing service/overhaul manuals for the '65 Corvette are the 1963 Corvette Shop Manual and 1965 Corvette Supplement. Overhaul procedures, including the alternator, are in the former.
            1966 was the first C2 year that required Corvette owners to buy separate "service" and "overhaul" manuals that covered all passenger car model lines.
            I agree that overhauling alternators is fairly straightforward for the DIYer, depending on what is required. Removing the pulley typically requires an impact wrench to break the nut loose, and an arbor press to remove the bearings.
            It might help if the OP states why he thinks the alternator needs to be rebuilt or replaced.
