1963 Battery Kill Switch - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 437
    Tried installing this and the lever hits the blower motor terminal connector. Unless someone else with a non-A/C Coupe has had success with this type of switch, guess I will get try the horizontal blade version or get the green knob-style.
    Thanks in advance - Fred
  • Harry S.
    • July 31, 2002
    • 5295
    Fred, I have one on my 63. I can't get to it to take a picture.
    What I recall doing is taking the switch apart and reversing the switch. Others will comment I'm sure.
    • Larry E.
      • 1677
      Frederick: That's the same one I use on my 66 Base Coupe. As Terry M. has indicated
      on a past thread: IT MAKES NO DIFFERENCE IF YOU BREAK THE POSITIVE OR NEGATIVE SIDE
      OF THE CIRCUIT. I break the positive side and lay that exact switch "Parallel" and reversed (as shown) to the engine.
      Works great and easy to get to and also looks good-Larry
      Larry
      LT1 in a 1LE -- One of 134
      • Frederick H.
        • August 31, 1983
        • 437
        Thanks for the feedback guys. Harry, I can't believe I didn't think of that - gotta slow down and put a little thought into it .
          • 15599
          LARRY - You took the words right out of my mouth.
          Thanks for the quote.
          • Larry E.
            • 1677
            IIRC when I bought the above there are several options with this Top Post switch.
            I bought the one with the added wingnut to secure the the cable tighter. Larry>Picture
            below.
            Larry
            • Frederick H.
              • August 31, 1983
              • 437
              Good point Larry. It's actually the negative post/cable that I have not been able to secure with pliers only (no kill switch installed yet). I have to take a small hammer to tap the spring ring portion down on the terminal (AC Delco 24G series). I believe it has to do with the terminal having a slight taper?
              • Larry E.
                • 1677
                Frederick:Very true on your comment. If you buy some proper
                Size washers(lock type) (Menards) you can get a very good
                Tight fit with the positive cable. Larry
                Larry
                • Sven C.
                  • July 18, 2015
                  • 188
                  Frederick. Just a pic of the kill switch on my '63 coupe.
                  1963 Corvette: Flight Judging Award (Top Flight) at 2023 Ontario NCRS Regional Meet (Regional) at 09-14-2023
                  1963 Corvette: Flight Judging Award (Top Flight) at 2023 National Convention-French Lick (National) at 07-27-2023
                  1963 Corvette: Flight Judging Award (Top Flight) at NCRS Indiana Regional (Regional) at 04-28-2022
                  1963 Corvette: Flight Judging Award (Top Flight) at Ontario Chapter judging Meet 2021 (Chapter) at 09-18-2021
                  • Larry E.
                    • 1677
                    Thought I would share a picture of my Battery Knife Switch on my 66 Base Engine Coupe.
                    Thanks>Larry
                    Larry
                    • John F.
                      • March 23, 2008
                      • 2408
                      Here is my 64 non-a/c car.
                      • Frederick H.
                        • August 31, 1983
                        • 437
                        Thanks for all the photos guys - good info as always.
                        Fred
                        • Joe M.
                          • February 1, 2005
                          • 590
                          Marine cutoff switch in POS cable, mounted on firewall passenger foot well. Able to reach it from driver seat. Otherwise.....In an emergency you have to pull over, pop hood, allow air in to fuel the fire, get out on roadside, run around car, fight fumes, smoke and flame, reach in to flip switch.
                          Boats required to have a battery cutoff when fueling. After all, it is a corvette....
