What is the recommended best coolant to use for my 1967 small block?
Recommended Coolant
Tags: 1967, 1967 427 390hp, 1967 427 400hp, 1967 427/400 tank sticker, 1967 435 tank sticker, 1967 and 1965, 1967 bolt on wheels, 1967 c2 kick panel, 1967 c2 seat restoration, 1967 corvette question, 1967 Dash, 1967 dash cluster, 1967 door panel, 1967 harmonic balancer, 1967 L88, 1967 N14, 1967 radio volume, 1967 rally wheel, 1967 shielding, 1967 shoulder harnesses, 1967 starburst caps, 1967 tank sticker, 1967 timjg, 1967 window channel
Ira, this similar thread is so recent it is still on the first page of threads.. You could find it by using the search box above with your key words 1967 Coolant.. The magic stuff is Zerex G05, not Z (G)06 like I identified it.
https://www.forums.ncrs.org/forum/te...freeze-coolant- Top
