1964 C2 Anti Freeze / Coolant - NCRS Discussion Boards
  • George B.
    Infrequent User
    • January 19, 2024
    • 22
    What is the recommended Anti Freeze / Coolant for a 1964 C2 Corvette? Engine is 350. And how full should the reserve tank be?
  • Mark L.
    • 561
    George, this question has been asked a few times. I'm sure there is something in the Tech Archives.
    • Don H.
      Moderator
      • June 16, 2009
      • 2273
      George, assuming you're still running your aluminum radiator in your 64, then Zerex G06 is the coolent, and the expansion tank should be half full when cold as indicated on the tank.
      • Gary B.
        • February 1, 1997
        • 7054
        Don,
        Maybe you meant to say G05 instead of G06?
        This is what I just put in my ‘66.
        The pre-diluted is more expensive than getting the full strength and then diluting with distilled water.
        Gary
        • Don H.
          Moderator
          • June 16, 2009
          • 2273
          I had someone's new Z06 on my mind.
          • Joseph L.
            • July 26, 2012
            • 162
            If you like the Zerex brand, you can also use Original Green. Do not use Dex-Cool, it is not good with older cars. Do not mix coolant types (IAT, OAT, HOAT).
            Joe
