1954 Corvette ribbed rubber frame pads location - NCRS Discussion Boards
  • Tim M.
    Infrequent User
    • July 14, 2012
    • 29
    Is there a diagram somewhere that shows the location of the 3 1/4 x 1 1/4 ribbed rubber frame pads on a 1954 Corvette? Thanks.
  • Rod K.
    • 445
    Do you have the factory Assembly Instruction Manual? That should show locations. If not, I have '57 AIM but maybe someone with '54 will chime in just in case they're not quite the same.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17947
      Tim,
      Don't know your circumstances. Always best to take lots of photos during a disassembly.
      The 53-5 AIM is very crude compared to the 56-7 AIM. Did not find any pages in the 53-5 AIM that referred to the underbody shims.
      Below is an excerpt from the 56-7 AIM that shows the underbody shims.
      Found in '57, often there was more than 1 shim stacked ontop of another.
      Good luck,
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Mike M.
        • May 31, 1974
        • 8408
        I place the ribbed pads anywhere the floor pan is close enough to the frame to cause noise. doubt the judges will have a problem with pads anywhere u locate them.the sole purpose of the pads was to prevent the fiberglass floor pan from making contact with the metal frame. mike
        • Leif A.
          • August 31, 1997
          • 3654
          Couple of pictures of C1 chassis. First one is from Jeff and the second one from John Hinckley (RIP).
          Jeff's picture shows five shims (he's sitting on the sixth) and John's picture shows a restored chassis with the shims in the same place they were prior to restoration.
          Chris Sherman has some terrific pictures of '53 - '55 chassis with the ribbed shims...can't find them at the moment. You might try contacting him through this Forum...he's a member.
          Leif
          • Leif A.
            • August 31, 1997
            • 3654
            Here's a terrific picture (courtesy of Chris Sherman).
            Leif
