1968 Wiper Issue - NCRS Discussion Boards
1968 Wiper Issue
  • Daniel P.
    Infrequent User
    • January 12, 2020
    • 3
    1968 Wiper Issue
    I cannot get my wipers to work on my '68. I started by checking the fuse and blower motor ground; then the override switch and door limit switch; then the relay and the motor; all checked okay. I found a loose ground connection for the override and door solenoid: started working but the washer pump stays on. shut them and now they don't work again. I have tried grounding each component separately too. I had a Corvette shop back in the 70s and have fixed these issues.
  • Mark E.
    • April 1, 1993
    • 4606
    How specifically does it not work? Does the door open and close using the wiper switch and the over-ride pull knob?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Daniel P.
      Infrequent User
      • January 12, 2020
      • 3
      Right now I have the door manually open. I even checked the negative battery cable to frame connection; ground to block and; ground to starter connections (everything is ground driven on a '68). originally before I found the ground issues on the override bracket under the column, that to lead to a brief operation of the wipers, I would hear a click at the motor. Now I hear nothing.
