63 Fuel injection air cleaner mounting - NCRS Discussion Boards
  • Todd L.
    • November 24, 2020
    • 275
    Hey guys,
    The JM states "The air cleaner attachment parts are not installed until the air cleaner itself is installed." Is this referring to the S-tube and bellows as the "attachment parts"? Was the air cleaner canister installed before undercoating? If so, would the plate, screws and large fender washers all be undercoated inside the wheel well?
    Thanks!
    Todd
  • Joseph S.
    National Judging Chairman
    • February 28, 1985
    • 837
    Todd, The attaching hardware inside the wheel well should not have any undercoating or blackout on them.
    Regards, Joe
    • Don H.
      Moderator
      • June 16, 2009
      • 2239
      just to reaffirm Joe's answer.
      • Todd L.
        • November 24, 2020
        • 275
        Don,
        Yours appear to have some blackout or undercoating on them, which is not what Joe stated. Can you clarify?
        Also, your "A" marked bolt heads are different from what I have. I looked in the AIM and the part # is 9417692 for these bolts. When I searched that part # I find in multiple places that these bolts are also for the spare tire, and marked TR or RBW. Do you know if there were all of these head markings used?
        Todd
        • Don H.
          Moderator
          • June 16, 2009
          • 2239
          no undercoating at all.. Yes, there is black paint.. I suggest follow Joe's advice, and use your bolts if they have headmarks commonly seen on early mid-years, until proven to be not correct.. I don't know what all headmark bolts used were.. Good luck
          • Dan H.
            • July 31, 1977
            • 1366
            My 64 has impressions of the retainer/washer into the under coat indicating the were installed after the under coating process. The common head marks I've seen are 'A' and also blank ones.
            Dan
            1964 Red FI Coupe, DUNTOV '09
              • May 31, 1974
              • 8370
              Dan
              I agree with dan. when I restored our 65 FI roadster, with 19900 original miles that I bought in 1970, there was bare fiberglass under the rectangular plate and the individual fastener/washer below the rectangular plate. hence I believe the air cleaner assembly was installed BEFORE the blackout/undercoating was applied. mike mccagh
              • Joseph S.
                • February 28, 1985
                • 837
                Sounds like Andy should research this further. ....At what point would the undercoating have been applied? At what point would the air cleaner assembly be applied?
                • Joseph S.
                  • February 28, 1985
                  • 837
                  Don, What does it look like under your bracket or washer? Undercoating or Bare fiberglass.
                  • Todd L.
                    • November 24, 2020
                    • 275
                    I agree with you Joe. It appears we are getting 63 and 64 responses here. Were they all the same, or did the process change from 63-64? Also, mine is a December 62 build, so was that changed throughout the 63 year as well?
                    • Alan D.
                      • December 31, 2004
                      • 2030
                      For my Mar64 car; it is natural, ie NO undercoating. Recall this being study before, and still have that raw plate.
                      The following is from
                      2011 NCRS National Convention Technical Seminar
                      Presented by John Hinckley, Michigan Chapter
                      MIDYEAR CORVETTE ASSEMBLY PROCESS (items listed in order of assembly)
                      Wheel well air-dry sound deadener/undercoat material was applied
                      after the final bake oven and the black-out booth, with airless spray
                      guns fed from 55-gallon drums; no masking or shielding was used,
                      and care was taken to keep the material off exterior surfaces and
                      away from the #3 body mount access hole.
                      Assemble engine and forward lamp harness multiple connectors to
                      engine compartment side of fuse block.
                      Connect positive and negative cables to battery terminals.
                      Install temporary driver’s seat
                      Prime carburetor with gasoline through bowl vent tube.
                      Start engine (check neutral safety switch function on Powerglides),
                      check for good oil pressure, fluid leaks or unusual noises, adjust idle
                      if required.
                      Install air cleaner.
