C2 C60 Hot Water Cutoff Vacuum Switch - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5346
    I have a switch apart. The O-Ring is worn out. I believe it's an LIC replacement brass switch.
    Would anyone know the size/dimensions of the O-ring.
    Here is a thread I found on the Board ----> https://www.forums.ncrs.org/forum/te...ns#post1016214
    I'm still measuring to see if the dimensions in the thread are from an OEM switch or an LIC switch.
  • Leif A.
    • August 31, 1997
    • 3654
    Harry,
    Dave Tracy posted this on the "other" forum...should be very helpful.
    https://www.corvetteforum.com/forums...ir-i-hope.html
    Leif
    • Harry S.
      • July 31, 2002
      • 5346
      Thank you, I'll contact him
      • Harry S.
        • July 31, 2002
        • 5346
        The one I have has no marking, so it must be from LIC. I took some surgical tubing and cut to fit. Some silicone grease and it works fine. Before I peen it back together, I'll look for better tubing. Should be a good solution.
        • Harry S.
          • July 31, 2002
          • 5346
          Definitely an LIC switch. I finally, today, got the last pieces of the old flat-o-ring out. There must have been two in there, but I can't tell where they were installed or even measure their dimensions.
          Has anyone take one of these apart and documented how it was originally assembled? It is different than the OEM part.
          Cheers.
          • Larry M.
            • January 1, 1992
            • 2702
            Harry:
            Send me your email and I will send you my write-up on the rebuild. Or I can provide it to you thru the other forum (CF).
            Larry
            • David Z.
              • April 1, 2002
              • 183
              I pulled the info in the attached pdf from the CF some time back. It includes Larry's write-up along with other info. Hope this is OK Larry.
              Dave Z
              Identification and Repair of 63-67 Heater Vacuum Valve.pdf
              Dave Zuberer
              • Larry M.
                • January 1, 1992
                • 2702
                THANK YOU Dave.................as always you have the best repair tutorials for our old cars........ bar none. I always enjoy and save your work for my later reference.
                Larry
                • Harry S.
                  • July 31, 2002
                  • 5346
                  Larry, I sent a PM a few days ago.
                  Harry
                  • Harry S.
                    • July 31, 2002
                    • 5346
                    I haven't been lazy just busy. Finally getting around to the LIC switch.
                    I removed two o-rings from the switch. One was on the shaft and one was stuck at the bottom of the brass tube. Probably to seal the end by the piston.
                    How many o-rings did you find in the LIC switch.
                    If I did my math correctly, I need..
                    Top O-ring ID of 4.78 MM, OD 5.842MM, two to fill he space
                    Bottom O-ring of 2.286 MM, OD 5.842 MM, one to form a seal
                    Harry
