1956 Clutch Fork - NCRS Discussion Boards
1956 Clutch Fork
  • Sheldon S.
    • March 1, 1999
    • 478
    1956 Clutch Fork
    I am trying to identify which fork to use on my 56 . I had put one in but have now realized the curved part is way too much and have another one I think will work. I have pictures but can't figure out how to upload the pic. Is there some way to visually figure out what should be used. I have 3 different ones, two are the style that are used in the late 56 through 62 with the pin that goes through the end of it into the adjusting rod. The other one has a hole in the end for the style that was used early 56.
    Any info greatly appreciated.
    Sheldon
  • David B.
    • March 1, 1980
    • 689
    Look in a '57 parts book under Grp. 0.795 There is a 1955-57 clutch pedal illustration etc. also will give correct part numbers and description for what your looking for.
    • Joseph L.
      • July 26, 2012
      • 162
      Hi Sheldon
      Look in the JM for the clutch fork configuration. It has to match with the 1956 pushrod end. I am assuming you want a typical fork.
      Joe
