I'm rebuilding a 66 telescopic steering column which is missing the plastic covering for the turn signal ribbon cable. It is referred to as the Directional Wiring Cover in the GM exploded diagram.
I found the attached picture which I assume shows an original and its position on the column.
This part is reproduced for the standard column, but the one for the telescopic column is quite different and I have not found a source for one.
Anyone have either a source for one or a substitute solution? I know the telescopic one is longer than the one for standard column so I have two of the standard column ones on order thinking maybe I could make one telescopic cover from two standard column covers!!
