1966 Telescopic steering part search - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    I'm rebuilding a 66 telescopic steering column which is missing the plastic covering for the turn signal ribbon cable. It is referred to as the Directional Wiring Cover in the GM exploded diagram.
    I found the attached picture which I assume shows an original and its position on the column.
    This part is reproduced for the standard column, but the one for the telescopic column is quite different and I have not found a source for one.
    Anyone have either a source for one or a substitute solution? I know the telescopic one is longer than the one for standard column so I have two of the standard column ones on order thinking maybe I could make one telescopic cover from two standard column covers!!
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Tom D.
    • September 30, 1981
    • 2151
    Don: What is the number of the part you ordered (Paragon number, Or GM number, or Corvette Central number)? Also, do you know the GM number for the telescopic column version?
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Donald H.
      • November 2, 2009
      • 2594
      Tom,
      The ZIP part # for the standard wire cover is SC-737. Looks like most all the vendors carry this one. Corvette Central part # 562049.
      I have not been able to find the GM number for either the standard or tele. I have an old dealer parts catalog and if either of these are in it, I couldn't find them.
      Don Harris
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11370
        Don, The info may be in the prints. See this thread for the pdf's....
        https://www.forums.ncrs.org/forum/te...19#post1313019
        Edit... I can see the plastic sleeve but no part number is shown. (52/53 Pdf's)
        P.S. Ignore the link below. I cannot delete it.
        • Tom D.
          • 2151
          Under SPECIFICATIONS on the Corvette Central website, they say the part you bought is a repro of GM 3841555
          Another site shows a different looking item, for non-corvette tilt columns?
          Michigan Chapter
          Tom Dingman
          • Keith B.
            • September 15, 2014
            • 1604
            that looks nothing like what's used on the tele on my dads 65
            • Donald H.
              • November 2, 2009
              • 2594
              Yes, the diagrams show the sleeve/cover. They do help though. They don't show the length of the sleeve, but I can tell that it is up in the bell even when the column is extended and where the other end fits. Hopefully I can take two of the standard column covers and make something that will work.
              Don
              Don Harris
              • Dorsey F.
                • April 11, 2022
                • 35
                Don, I searched for one of these for several years with no luck. I believe the overall length will be ~15” and is taped to the wiring harness at the lower end. The standard steering looks (from pictures) to be the same plastic extrusion, but closer to 10” with the hole at the lower end to attach to the column. The standard column cover is really tight in the escutcheon, which makes me wonder if it is the same extrusion.
