Rotor Runout - NCRS Discussion Boards
Rotor Runout
  • Michael C.
    • January 9, 2013
    • 332
    Rotor Runout
    I've read many posts regarding rotor runout here and other forums. And watch several videos. Only one instruction that the rear hubs/rotors should be raised to approximately riding height before measuring runout. Is this a requirement? If yes, does this mean the front should also be raised? 69 BB.
    Mike
  • Jim L.
    • September 30, 1979
    • 1817
    The probable reason for raising the rear hubs is to prevent U-joint binding as the rotor is turned during the measuring process. No such requirement exists for the front hubs..
    • Michael C.
      • January 9, 2013
      • 332
      Thanks for the quick reply Jim. One less concern to check off the list.
