1963 Parking Brake Alarm Switch Installation Issues - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1312
    I'm trying to install this switch for a friend of mine and I'm have trouble keeping the interlocking part of the switch engaged while I'm tightening the small bolt that goes through the hole in the picture. When I tighten this bolt, the interlocking part stays in place, however when I go to tighten it to lock it in place, the interlocking section comes loose.
    My thought is that maybe the hole in these pictures is a bit too big and it's pulling one side into the switch at an angle which distorts the "squareness" of the switch.
    A possible solution is to put a bolt in that's the size of the extended hole and re-tap the other side to fit. Other than that......I got nothing!!
    Thoughts on a solution will be appreciated.
  • Harry S.
    • July 31, 2002
    • 5346
    An NOS switch, never installed. Hole looks the same size.
    • Arland D.
      Moderator
      • July 31, 1980
      • 430
      Can you unplug the switch from the harness and take pictures from all four 'sides' showing the strap, switch plunger, attaching surface and the other half of the bracket?
      • Gerald C.
        • June 30, 1987
        • 1312
        Will do as I stop over my friend's house. Harry already gave me a hint on how to straighten the bottom of the switch in order to make it fit.
