73 Speedometer Face - NCRS Discussion Boards
73 Speedometer Face
+ More Options
Posts
  • David C.
    • January 23, 2024
    • 47
    73 Speedometer Face
    When I bought my 73 it had aftermarket electric speedo and tach installed. I'm going to be restoring them to original mechanical units but I have no originals to compare with. The replacement units from OER look good except for the openings for the turn signal and warning lights. These openings have a white edge where the white underlying material shows through. Is this how the originals looked?
    73 Coupe, L-48, auto, Body Build Date: 31 May 1973
    Member - Southern Nevada Chapter NCRS
  • Brian T.
    • September 30, 1990
    • 190
    The pointer on their repros is absolutely awful as well.
    • John S.
      • June 15, 2015
      • 508
      Dave, a little too dark in the garage tonight to get a pic, but I can confirm that there is no white edge on the turn signal area of my speedo or Tach. Iโ€™ll try to get a photo in the daylight tomorrow.
      1973 L82 M21 4 Speed, very original and well documented driver/survivor
      NW Chapter Member, 2016 Bend Regional Top Flight
      73/74 TIM&JG 3rd Edition Revision Team Member
      • John S.
        • June 15, 2015
        • 508
        Dave, attached photos for your comparison. Sorry about the glare but I think theyโ€™ll help you compare to the reproduction faces. Both of my gauges are original and have not been out of the car for any reason. Clearly no white outline at either the directional, high beam or brake indicators. Note your redline on the tach will be different on your L48.
        You do not have permission to view this gallery.
        This gallery has 2 photos.
        • David C.
          • January 23, 2024
          • 47
          Thank you, John. I can touch up the white easily. It won't be perfect, but it'll be better. It's going to be nice to have the indicator and warning lights working again. I've been driving without them for a year now. So much for people's "upgrades"
