Engine pad stamp authenticity. - NCRS Discussion Boards
  • Jacob A.
    • December 1, 2003
    • 237
    Hi Everyone,
    I would appreciate your thoughts on this engine pad stamping. Factory, or not.
  • David H.
    • June 30, 2001
    • 1567
    [QUOTE=Jacob Angel (40987) ... I would appreciate your thoughts on this engine pad stamping. Factory, or not. ...[/QUOTE]
    Jacob
    A sharp, in-focus, image will most likely get you more and better responses.
    That said, there appear, to me, many diagonal (circular?) scratches above VIN stamp. (better focus of image in this area)
    This gives me impression of a block that has been decked. Also, stamp pad appears to set below height of water pump casting - again impression of a decked block.
    Sharp in-focus images would help.
    What is block casting number, casting date? What is VIN of car in question?
    Dave
    • David H.
      • June 30, 2001
      • 1567
      Cancelled post - duplicate response
      • Joseph T.
        • March 1, 1986
        • 169
        7120855 IL.jpgAppears OEM. Look at the assembly stamp of VIN 20855 ...same date and character set.
        • John F.
          • March 23, 2008
          • 2424
          Black Book indicates last Vin for month of May 67 was 19747.
          • Ronald L.
            • October 18, 2009
            • 3248
            what are the trim tag details?
            • Mark F.
              • July 31, 1998
              • 1611
              In addition to all said above, based on some commonly held beliefs about 1967 production quantities per day and per week (which may, or may not be accurate), comparing your engine assembly date with your VIN Derivative on the pad, I'd estimate your Body Build Date (BBD) on your the trim plate is either K9 or K12.
              We'll see if that’s close when (or if) you can post a shot of your Trim and VIN plates.
              Both fit within commonly accepted timeframes from engine assembly; shipment to St. Louis; and final assembly (14 calendar days or 9 production days if BBD=K9; 17 calendar days or 12 production days if BBD=K12)
              thx,
              Mark
              • Jacob A.
                • December 1, 2003
                • 237
                thanks everyone.
                here are the tags..
                • Jack M.
                  • March 1, 1991
                  • 1199
                  The assembly date comparison:
                  An animation regarding a double strike (or more) VIN stamp:
                  • Leif A.
                    • August 31, 1997
                    • 3658
                    Jacob,
                    Your car was assembled on Monday and mine was assembled two days later on Wednesday. The same guy who double stamped your pad must have done mine, as well. I think you're good to go.
                    Leif
                    • Mark F.
                      • July 31, 1998
                      • 1611
                      Originally posted by Jack Morocco (18851)
                      The assembly date comparison:...An animation regarding a double strike (or more) VIN stamp:
                      Very Cool, Jack...
                      I noted that the "5" was more faint on both EADs, so that must have been wearing out - or set deeper in the gang stamp tool at Tonawanda...
                      thx,
                      Mark
                      • Andy C.
                        1963-4 Team Leader
                        • April 1, 1998
                        • 119
                        Notice the upside down 8 In both VIN #s 830, 855
                        • Thomas H.
                          • August 31, 2005
                          • 1068
                          FWIW, Stamping from my 67 one day prior. Shows same "light" 5 after the deeper "0"
                          2007 Z06, Lemans Blue
