On an automatic what 2  wires can i short across to by pass the neural safety switch to  get the  car  to  crank.? Or  is  there a  way to  test the  switch to see if its  bad ?  Thanks
					1965 neutral safety switch powerglide
Paul, the safety switch simply connected at the purple wire to starter solenoid Male/Female connector usually lightly wrapped with friction tape in harness just above the wiper /washer motor. I do not know what you have left from switch harness, but if you simply plug the harness together ( as seen on a 4 speed car) it will bypass the switch, as the switch simply plugged in there, interupting the solenoid input. Then, be careful!- Top
