deck lid receiver removal - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    feeling like this should not stump me but it has. how do remove that nut that I can't get to straight on because of the pin and that is too recessed to get from the sides???
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • Dennis C.
    • June 30, 2002
    • 888
    Re: deck lid receiver removal
    I would suggest using an offset wrench. If you don't have one with the correct offset, I would make one. Take an inexpensive wrench, heated and bend to the desired shape.
    • Keith M.
      • January 17, 2021
      • 695
      Oohh..never knew those existed. Cant remember the name of those little open end pieces you put in a socket...what are they called?
      • Keith M.
        • January 17, 2021
        • 695
        Crowfoot. Might those work?
        • Don L.
          • August 31, 2005
          • 1006
          Don Lowe
          NCRS #44382
          Carolinas Chapter
          • Leif A.
            • August 31, 1997
            • 3654
            Crows feet.
            Leif
            • Dennis C.
              • June 30, 2002
              • 888
              Maybe, but I think your best bet is a box wrench bent to the right angle. This would require a less movement to loosen.
              • Rocco S.
                • December 21, 2013
                • 180
                Keith,
                Snap On and probably make deep offset box wrenches that will probably work too. You don't say what the hex size is but the photos are 3/8" X 7/16". Good luck.
                ROCCO SCOTELLARO
                1967 Lynndale Blue/Black Coupe L79, M21, G81 (3.70:1), A31, A82, C60, K66, N11, U69
                • Keith M.
                  • January 17, 2021
                  • 695
                  This is turning out quite well as I love it when the solution ends up with a new tool!!! I am gonna pick up a set of Craftsman offset wrenches from Amazon for $48. I had been thinking about a set of crows foot for a while but they are $63 and I think for this need the offsets are better. I probably do have a random wrench of appropriate size that I could bend but what I don't have is a welder and I don't think MAP gas gonna do the job to bend it.
                  Thanks all. much appreciated. Probably too late for Santa to get the wrenches under the tree. And many might say I not been a good boy anyway. Merry Xmas!!
