green zinc chromate paint - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 321
    looking to see what people are using for AO smith green zinc chromate paint
    Quanta no longer lists it . any info would be great
    Bob Peckham
  • Michael H.
    • December 1, 2004
    • 118
    Re: green zinc chromate paint
    Moeller Marine Products - “Zinc Primer - Outboard & Tern Drive” 025802-1”. It can be purchased at West Marine.
    • James W.
      • December 1, 1990
      • 2671
      I purchased mine from aircraftspruce.com.
      3Chem Zinc Chromate Green
      16 oz. aerosol can
      Part # 09-06310
      MFR Model # P-10061
      $16.75 per can
      Amazon also sells SEMS #39693 green self-etching primer.
      Hope this helps.
      James
      • Gary B.
        • February 1, 1997
        • 7064
        Bob,
        I used Moeller Zinc Chromate Green #025472. I test sprayed several brands of zinc chromate and the difference in color was obvious. The Moeller matched best to some original parts that were zinc chromate on my car. I checked for the Moeller zinc chromate just now and it looks like it might be discontinued and replaced with Moeller zinc phosphate.
        Gary
        • Robert P.
          • October 19, 2019
          • 321
          thanks for all the info , the quanata paint( almost full) which i have that is 5+ years old according to the date on the can spits out small specs of yellow colored paint from time to time and will not dry. I figure farther time has caught up with the can of paint.
          Bob
          • Gary B.
            • February 1, 1997
            • 7064
            Bob,
            Will you be spraying new zinc chromate green next to original zinc chromate green so that you need a good color match? If so, you might need to buy several brands and see which is closest. The two brands I sprayed were quite different greens.
            Gary
            • James W.
              • December 1, 1990
              • 2671
              A picture of my unrestored, AOS bodied '65 coupe, VIN 2209x built in the last week of June. The original zinc coating on the car is more on the light green/yellow side. Cleaned only with Simple green and water.
              James
              • Robert P.
                • October 19, 2019
                • 321
                thanks for the pictures that is the color i am trying to get 3rd week of sept 1965 , my dash cross bar is just like that
                Bob
