1964 Corvette Tachometer stopped working - NCRS Discussion Boards
  • George B.
    Infrequent User
    • January 19, 2024
    • 22
    1964 Corvette RPM gauge / tachometer stopped working. Initially thought the cable broke. Replaced the cable and tach still does not register. Appreciate any thoughts as to what could be the issue....
    Thank you,
    George C2
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 1964 Corvette Tachometer stopped working
    first I'd check that the tack drive gear within the distributor isn't stripped or the gear on the distributor main shaft gear isn't stripped. pulling the distributor out is easier than pulling the dash cluster out to repair the tack itself if the gears in the dizzy are intact. good luck, mike
    • Dave S.
      • August 31, 1992
      • 2930
      Thank you,
      George C2
      • George B.
        Infrequent User
        • January 19, 2024
        • 22
        So, with new cable installed to back of Tach, I put the distributor end into a "drill" and the tach moved accordingly. Does that mean the drive in the distributor is stripped / gone?
        Recommended solution is to replace the whole distributor? or other.
        Thanks for the feedback.
        GB C2
        • Dave S.
          • August 31, 1992
          • 2930
          It seems your problem is with the distributor. As Mike suggested the gear in the distributor is defective in some way.You will need to pull the distributor and have it repaired.
